POV-Ray : Documentation : 2.1.2 Command-line Options
  POV-Ray 3.6 Documentation Online View
2.1.1 Notation and Basic Assumptions   2.1.2.1 Animation Options
The reference section describes all command line switches and INI file keywords that are used to set the options of POV-Ray. It is supposed to be used as a reference for looking up things. It does not contain detailed explanations on how scenes are written or how POV-Ray is used. It just explains all features, their syntax, applications, limits, drawbacks, etc.
Options may be specified by switches or INI-style options. Almost all INI-style options have equivalent +/ - switches and most switches have equivalent INI-style option. The following sections give a detailed description of each POV-Ray option. It includes both the INI-style settings and the +/ - switches.
The notation and terminology used is described in the tables below.
Keyword=bool Turn Keyword on if bool equals true, yes, on or 1 and Turn it off if it is any other value.
Keyword=true Do this option if true, yes, on or 1 is specified.
Keyword=false Do this option if false, no, off or 0 is specified.
Keyword=filename Set Keyword to filename where filename is any valid file name.
Note: some options prohibit the use of any of the above true or false values as a file name. They are noted in later sections.
n Any integer such as in +W320
n.n Any float such as in Clock=3.45
0.n Any float < 1.0 even if it has no leading 0
s Any string of text
x or y Any single character
path Any directory name, drive optional, no final path separator ("\" or "/", depending on the operating system)
Unless otherwise specifically noted, you may assume that either a plus or minus sign before a switch will produce the same results.
Amazon.com Wish List
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
